14. Python & Batch: pvpython and pvbatch
14.1. Introduction
ParaView can run without opening the ParaView GUI, and is controlled through Python. There are two Python interfaces - pvpython and pvbatch.
14.2. pvpython
pvpython
is the Python interface to ParaView. You can think of pvpython
as ParaView with a Python interface. As we did with the Python Shell,
you can manually type in commands to pvpython
. The first thing you will
want to do is import paraview simple, as follows:
from paraview.simple import *
pvpython
can also read Python command files. Type pvpython –help for
arguments. Running pvpython
files looks like this:
/pathTopvpython/pvpython /pathToPythonCommandFile/commandFile.py
# Example
D:/alan/paraview/pvpython D:/alan/scripts/disk_out_ref-A.py
You will notice that
pvpython
will run the script and then exit. The output of the script is a screenshot or other data product.Anywhere that needs editing in the scripts above will be marked by the string editMeHere.
You will need to hard code in the paths to your data, and paths for output products.
The first time you run a script with
pvpython
, the output will be a postage stamp sized window. You can change this by finding and uncommenting the line renderView1.ViewSize.Try making and running a script of your own. Alternatively, here is an example. Cut and paste the following into a file named greenSphere.py:
#!/usr/bin/env pvpython from paraview.simple import # Lets create a sphere sphere=Sphere() Show() Render() # get active view renderView1 = GetActiveViewOrCreate('RenderView') renderView1.ViewSize = [1670, 1091] # get display properties sphere1Display = GetDisplayProperties(sphere, view=renderView1) # change solid color sphere1Display.AmbientColor = [0.0, 1.0, 0.0] sphere1Display.DiffuseColor = [0.0, 1.0, 0.0] # save screenshot SaveScreenshot('greenSphereScreenshot.png', renderView1, ImageResolution=[1670, 1091])
Run this as follows:
/pathTopvpython/pvpython greenSphere.py
14.3. pvbatch
pvbatch
is like pvpython
, with two exceptions. pvbatch
only accepts
commands from input scripts, and pvbatch
will run in parallel if it was
built using MPI. Input is exactly like pvpython
14.3.1. Generic user specific section
14.3.1.1. This section describes how to use pvbatch when on Windows PCs.
If you are training on Linux,
pvbatch
will exist in the bin directory.If you are training on OS X, open a terminal window, and cd to /Applications/ParaView x.x.x/Contents/bin.
pvbatch
will be located here.If you are training on Windows,
pvbatch
does not exist. But, for a single process, such as this training,pvpython
will substitute.
14.3.1.2. Lets create a Python trace.
Since we are on Windows, we will create a python trace, and use pvpython
to process it.
Read exodus data, screenshot, movie.
Run
paraview
.Select Tools → Start Trace
Open can.ex2.
Turn all variables on.
Apply.
+Y.
Go forward one timestep.
Set Coloring to EQPS.
Select File → Save Screenshot.
File → Save Animation.
Tools → Stop trace.
Save this script on your desktop
Edit the file and change the following:
Correct the path to the input data and output screenshots or animations (not necessary, since you made the trace)
Uncomment the line that says renderView*.ViewSize. Change this to something reasonable (maybe 1920x1080)
14.3.1.3. Let’s now batch run this Python trace.
Delete the Screenshot and Animation you made above. We want to recreate these.
Open a CMD window. (On the Start button, type cmd, then click on Command Prompt.)
cd to the ParaView bin directory
cd C:/Program Files (x86)/ParaView x.x.x/bin**
Use
pvpython
to process our trace. Notice thatpvpython
understands forward slashes.pvpython.exe C:/Users/myUserName/Desktop/trainingExampleScriptA.py
Open the Screenshot and Animation that you just made.
14.3.1.4. Let’s edit the trace to accept arguments
Edit the python trace.
Right above the ExodusIIReader, enter the following code:
datasetIn = sys.argv[1] directoryOut = sys.argv[2] imageFilesOut = sys.argv[3] print("datasetIn = " + datasetIn) print("directoryOut = " + directoryOut) print("imageFilesOut = " + imageFilesOut)
Edit the canex2 = ExodusIIReader line as follows:
canex2 = ExodusIIReader(FileName=[datasetIn])
Edit the SaveScreenshot(…) line as follows:
SaveScreenshot(directoryOut+imageFilesOut+'.png', renderView1, ImageResolution=[1425, 1324])
Edit the SaveAnimation(…) line as follows:
SaveAnimation(directoryOut+imageFilesOut+'.avi', renderView1, ImageResolution=[1424, 1324], FrameWindow=[0, 43])
Now, run in a command window as follows:
pvpython.exe "c:/Users/myUserName/Desktop/trainingExampleScriptA.py" "C:/Users/myUsername/Desktop" "coolVizA"
14.3.1.5. Generic Python Script for pvbatch on Linux
Here is an example running pvbatch
, without having to make a trace.
Make a file greenSphere.py, as described in the
pvpython
section.Copy greenSphere.py to be redSphere.py.
Edit redSphere.py
Change AmbientColor and DiffuseColor to be [1.0, 0.0, 0.0]
Change the output file from greenSphereScreenshot.png to redShpereScreenshotScreenshot.png
Make a file runner.sh
Edit as follows:
#!/usr/bin/bash /pathTopvbatch/pvbatch greenSphere.py /pathTopvbatch/pvbatch redSphere.py
Run as follows:
source runner.sh
14.3.2. Sandia National Labs specific section
This section is specific to the clusters and environment at Sandia National Laboratories.
14.3.2.1. pvbatch on the clusters
ssh into one of the clusters. pvbatch
can be run on the login nodes, and
magically will acquire compute nodes and run your batch visualization in
parallel. You will find test scripts at /projects/viz/training/paraview.
These scripts are run as follows:
/projects/viz/paraview/bin/pvbatch_chama_mesa
This is version x.x.x of |pvbatch|.
Incorrect number of argument supplied. Expecting 4 but have 0
Usage: /projects/viz/paraview/bin/pvbatch_chama_mesa <Nodes> <Minutes> <HERT estimate> batchFileFullPath
An example is:
/projects/viz/paraview/bin/pvbatch_chama_mesa 1 10 FY123456 /projects/viz/training/paraview/whipple-A.py
14.3.2.2. pvbatchOnNode on the clusters
pvbatch
can be run on the same nodes as your simulation. Ask ParaView
help for more information on how to use this feature.
14.3.2.3. Example scripts
Here are four examples. We are going to create scripts using the trace
recorder, then run these scripts using pvbatch
Run
paraview
.Tools → Start Trace.
Read g1s1.e.16.[0-15].
Go to last timestep.
Go back one timestep.
Tools → Stop trace.
Save this script on your cluster.
Edit the file, change the following:
Correct the path to the input data and output screenshots or animations.
Uncomment the line that says renderView*.ViewSize. Change this to something reasonable (maybe 1920x1080).
Read exodus data, Clip, Slice, screenshot, movie.
Run
paraview
Select Filters → Common → Clip.
Slice using Y Normal.
Tools → Stop trace.
Add the following line above ColorBy(….,(‘EQPS’)).
g1s110fpse16Display.SetScalarBarVisibility(renderView1, False)
Read exodus data, 2d plots, screenshot, movie
Run
paraview
Select point if possible.
Plot selection (or plot over line, if necessary).
Plot EQPS.
Tools → Stop trace.
Read cth data, extractCTHPart, screenshot, movie.
Run
paraview
Read cth-med/spcth.[0-3].
ExtractCTHParts - 1.
ExtractCTHParts - 2.
Tools → Stop trace.
